Suggesion no leaf count & table
telltay
Post by telltay »
For Notes section, if we setup a lot of leaf in each note, i suggest to add a count in bracket
eg
Root
-- Chlid1 note (2)
-- Child2 note
-- Child3 note
Also, I dont think the table function are very easy to use or expand.. especially when compare with other editors. I suggest to make it easier to add / remove columns or rows in between lines and at the end of the lines.
Has thanked: 1411 times
Been thanked: 984 times
Re: Suggesion no leaf count & table
Click on Tools->Options->Notes and enable the "Show number of sub-items" check box.
Which options would you like to see in addition to the ones currently present for table in notes?
tahoma
Has thanked: 11 times
Been thanked: 13 times
Post by tahoma »
I also have once posted this request, the one for a a count in brackets after the note name. It is still on my list of suggestions. You seem to misread: this is not about the sub-items in the Note tree, it is about the visibility of the number of leafs in a Note. I still would welcome such a feature, for I believe it will help me find information quicker if I see how many leafs a Note contains.
MetalDrop
Been thanked: 189 times
Post by MetalDrop »
tahoma wrote: Tue Mar 23, 2021 8:45 am Hi,
Mock-ups are often handy when suggesting some features.
If possible and if implemented I think it would be good to make [leaf numbers] a different shape and color than node children numbers.
Ah, I see now, thanks for the suggestion, surely noted!
