Pre-defined shortcut for switching between conversation <-> List
Telesto
Post by Telesto »
Lots of items have pre-defined shortcut, but this not the case for 'conversations' vs list mode
Has thanked: 1411 times
Been thanked: 984 times
Re: Pre-defined shortcut for switching between conversation <-> List
Could you please share your use case scenario as to why you need to switch in between the modes often?
Telesto
Post by Telesto »
admin wrote: Mon Mar 15, 2021 2:24 pm Could you please share your use case scenario as to why you need to switch in between the modes often?
Well lets say I prefer list in principle.. I'm in CC list of plenty of bug of bugtracker, and mostly don't delete e-mails. Normally I only interested in the last e-mail. If I want to look up the whole history, I visit the bugtracker. So conversation showing me (my own) junk.
However I do receive a few mailinglist in the same inbox. And these get hard to follow without conversation mode. Especially if you want look up something. In that case I would jump to conversation mode.
Somehow I assumed this quite regularly done. But well assuming I'm the exception for switching. What's the point of the 'conversation' mode button in the navigation panel. I really find the 'conversation' button disturbing. Which is again a reason to ask for shortcut, if there is a shortcut, the button in the navigation panel becomes even more superfluous. But well, now I have ruined my Salami tactics approach: https://en.wikipedia.org/wiki/Salami_tactics
Understood thanks, will surely keep your suggestion in mind when doing changes to the UI.
