Warning in case of identical note titles
- Has thanked: 17 times
- Been thanked: 8 times
I think it would be useful that a sort of warning pops up when I want to create a new note with a title that already exists in the same tree. Something like: "A note with the title 'XYZ' already exists. Do you want to add a note with the same title?"
So the accidental creation of duplicates could be avoided.
Re: Warning in case of identical note titles
Déjà vu: put forward similar request at MyInfo.
Obviously +1 from me
Mod alert, didn't read the forum policy, but hope this isn't seen as kind of marketing of other apps. Yes, there certainly is overlap, but EssentialPIM is surely excels in other area's
- Has thanked: 1412 times
All right, will implement this suggestion in the very nearest future. Thanks!
- Has thanked: 1 time
- Been thanked: 30 times
Please make this optional, one of the great things about EPIM is being able to have a lot of notes with the same name, and it would get really annoying fast to be warned about each and every one of them.
Got it, thanks.
Related to this: I think it should be more like an info tooltip. Optional sounds like you can it turn/off. Info tooltip holds the middleground (but not clue if this be implemented in a decent non disturbing (but informative) way
First of all thanks again to admin for his quick willingness to implement my suggestion.
But I see that his work is not easy with so many different opinions.
What I did not expect: that even such a "harmless" suggestion leads to reactions that complicate the matter.
First a user tells us that he/she prefers not to be warned/informed about possible duplicates because of having a lot of notes with the same name. I can't imagine that this is a common situation for many users. But o.k. - if the warning can be made optional, no problem for me.
But then another user writes that it should be better not optional (in the sense of turning it on/off) but more something like an info tooltip.
Personally I don't understand why something that I can turn on/off (e.g. by checking a checkbox) would be no good solution in this case.
Let's say I have the options (e.g. somewhere in the settings):
- "A) inform me when I start to create a note with a name that already exists
- B) don't inform me about it"
If I have chosen option A and therefore e.g. a window pops up whenever I want to create a second note with the name "XYZ" asking me directly "What do you want to do now?" (respectively "Do you nevertheless want to continue?" or whatever), this is not disturbing at all for me but the opposite: it is welcome. It is exactly what I want. An info tooltip is something that can be overseen much easier than e.g. such a window (or any other way of explicit warning).
And if - on the other hand - I have chosen option B I do not even need an info tooltip.
Just stopping by to say I have a bunch of notes with the same name too.Tester wrote: ↑Tue Mar 30, 2021 11:09 pm First a user tells us that he/she prefers not to be warned/informed about possible duplicates because of having a lot of notes with the same name. I can't imagine that this is a common situation for many users. But o.k. - if the warning can be made optional, no problem for me.
Quite a few people I know also keep notes like this:
2020
01-Jan
02-Feb
03-Mar
...etc
Or something of the like were you wind up with many duplicate named notes due to being the same for every month/year...etc
I also have a lot of notes with the same names, and don't need to be warned about them.
Ah, o.k. Once more we see how different the needs of the users of such software can be. I did not think of certain cases as your example because I use such programs for completely different purposes: dictionaries, various types of lists (e.g. my movies on DVD, book titles, ...) etc. For these purposes identical names are (usually) completely undesired: If I have already an entry (note title) e.g. for the word "flower" with its translation, a second entry would be confusing. Therefore the automatical detection of possible duplicates by the program (plus warning) is/would be of great help.
So I really appreciate that EPIM's team is willing to implement an option - satisfying (hopefully) all types of users.
- Been thanked: 15 times
We also use a lot of duplicate notes but for entirely different reasons than what's written above.Tester wrote: ↑Wed Mar 31, 2021 7:20 am
Mostly wanted to point out to you that despite "personal" being in EPIM's name, there are a lot of business/teams of people who use EPIM for industry reasons and our needs tend to be quite different than someone who is just cataloging information.
@Tester
I mostly use EPIM for book series writing and have a lot of notes named: Ch01, Ch02...etc
I also keep information trees for each series so I have a lot of duplicate notes named: World, Characters..etc.
Then I also have a huge number of sub notes attached to things with the same names to track certain information.
Well, I think the best solution at the moment would be to not change anything related to the feature.
That means that you have dropped again your plans to implement an option concerning this feature??
