How to disable --- +enter becomes a long horizontal line ???
dirmansyah
Post by dirmansyah »
Hello developers
In note module if I type "---" and push enter button, they become a long horizontal line.
For MSWord, there is an option to disable this similar behaviour.
For EPIM, where is the option to disable this ?
I use -------- and ======= for my own purposes and do not like if they change into other type of lines. I am tired of pushing ctrl z whenever the lines change.
Re: How to disable --- +enter becomes a long horizontal line ???
There's no such option as of yet. However, what you can do now in order for the dashes not to turn into a horizontal line is to press the space bar button after the last dash and hit enter.
dirmansyah
OK
Thank you.
alinares
Post by alinares »
I just discevered this feature. What other shortcuts like this are there? Is there a possibility of adding markdown shortcuts?
For example, writing ## would switch to Heading 2 style.
No, unfortunately, there is currently no feature to add, edit, or remove markdown shortcuts. However, we will add this suggestion to our to-do list for consideration in future versions of EPIM. Thank you for bringing it to our attention!
