Notes, select tree-collection from combobox (dropdownlistbox) above tree
r0n
Post by r0n »
Is it possible in the future to have an combobox (dropdownlistbox) above the tree which contains tree-collections.
This makes it easier to seperate main note groups and could unclutter the below tabs a bit more.
For example, the 'Developper' category can now have mutliple programming/scripting languages below in the tabs:
[c++] [javascript] [HTML]
See below example image, sorry it is crude but I hope you get the idea.
Re: Notes, select tree-collection from combobox (dropdownlistbox) above tree
Thanks for the suggestion, noted. Although that combo box is going to be used for a bit different option in EPIM 10.0 (so you could quickly choose to see favorite, recent, etc. notes).
r0n
Post by r0n »
Thank you!
Tester
Has thanked: 17 times
Been thanked: 8 times
Post by Tester »
admin wrote: Fri May 14, 2021 8:14 am Although that combo box is going to be used for a bit different option in EPIM 10.0 (so you could quickly choose to see favorite, recent, etc. notes).
Just to be sure:
Hopefully such a combo box will not replace the plans for a filter notes box as discussed here: viewtopic.php?f=3&t=35454 (?). I ask because it seems that both should have the same position (above the tree).
That is something completely different.
