Linking and printing open items (notes, tasks...)
Chris17
Post by Chris17 »
From each list, one may create/copy an internal link or an instant-print from any item form the context-menu.
But during work with opened items (p.e. to edit them), it is hard to search them evereytime in the list if You want to copy a link of the active item or to do a print from it.
By the way, especially printing of all/only marked text is not possible.
Sample for links:
to get an overwiev over the history of a task/conversation, it is recommandable to note all calls, letters and emails to it with some comments.
Instead of writing large comments, it is very elegant to set a link on an email or a letter (letter as an external file).
You get the doubkle speed or more if You can copy the link of/to an email directly during reading or writing it without changing windows.
It is the same to take a hardcopy for a paperfile.
So please make it possible to do this by an opened item too.
Keldi
Has thanked: 26 times
Been thanked: 92 times
Re: Linking and printing open items (notes, tasks...)
Post by Keldi »
Chris17 wrote: Fri May 28, 2021 2:01 pm create/copy an internal link or an instant-print from any item form the context-menu.
+1
I'd like to have the 'Copy as Link' in the context menu of any opened item.
Or a keyboard shortcut for coping to the clipboard the link to the active item.
Or both.
Thanks for the suggestions, noted.
Chris17
Post by Chris17 »
In the meantime, I have lost some text of a task during writing a lot of text.
So I wished to have had a Save-Button too.
EPIM seems not to save an opened item byself.
It does sometimes; unfortunately if You inadvertently have changed text You didn´t want to change ;-). Up to now I couldn´t find out when/when not.
Does anybody know something about?
