Email editor
OcoboTully
Email editor
Post by OcoboTully »
The editor that there is to make emails is very simple, compared to the editor of the notes.
For example, in the notes editor, I can insert rows and columns in a table, and also customize it.
I would like to be able to use the same editor to post as the editor in the notes.
Has thanked: 1406 times
Been thanked: 977 times
Re: Email editor
Thank you for the suggestion, noted.
