"translated in google ".
I usually organize my tasks weekly on the calendar. In the calendar module you can drag the tasks which makes it easier.
My tasks are set to "STATUS: STARTED, PENDING, IN PROCESS, ETC.).
In the calendar I put the tasks "in process". If you could filter the tasks in the module, you wouldn't have to look for which tasks are in that state.
This is my particular case, but I am sure that other users would use these filters for their form of organization.
Greetings
Be able to filter tasks in calendar module
Re: Be able to filter tasks in calendar module
Why not use the search box at the top? In this case you'll be able to filter out any not needed items. You can also do that in the Table view by clicking on the Filter button on the toolbar.
I've been looking at the options you propose. These options only filter once tasks are dated.
What I propose is the reverse. Filter where it says "TASKS" (to the right of the calendar) by status (or label, etc) "in process" and once filtered, put the date by dragging it to the calendar. Once on the calendar I would adjust the details.
I see what you mean. What you can do is to filter tasks in the Tasks module and once this is done switch to the Calendar one. You should have the same view for a particular list there.
I have done what you asked me to do. It does not work, the tasks are not filtered.
The last option you have proposed is a very good one. I hope you take it into consideration.
Any other proposal?
Greetings
Any other proposal?
Greetings
Will surely do. Let's see if we're able to make it work in the next EPIM update already.
