Search only at the beginning of a word
Tester
Has thanked: 17 times
Been thanked: 8 times
Post by Tester »
For my needs typing letters into the search box should produce as search results only words which begin with these letters. But I assume that other users may have different needs. So I do not dare to suggest this as a general principle.
But please consider to create an option so that search takes place only at the beginning of a word and not somewhere in between it (at least for searching in Titles).
Here is an example:
Currently when searching for the word nation I will get as results also:
- alternation
- combination
- consternation
- coordination
- declination
- determination
- donation
- international
- multinational
etc.
When searching for a specific term all these results are undesired.
You can find an example for such an option e.g. in "AzzCardfile" (http://www.azzcardfile.biz/). The option is called there "Match start of Title".
Thank you.
Re: Search only at the beginning of a word
Thank you for the suggestion, noted.
