No update to 8.54 available on Win10
Trinitylab
Has thanked: 12 times
Been thanked: 37 times
Post by Trinitylab »
A very odd behaviour:
1. yesterday, on the guest PC, Win 10 x64, when I launched EPIM, I got the message there was an update to 8.54. I was surprised, as I haven't got that on the host, with EPIM launched 4 hours earlier, so I skipped the update, as DB was already opened in 8.53.1 on the host;
2. today, on the host, Win 8.1 x64, I got the message on the update, while launching EPIM, so I updated it to 8.54;
so far so good;
now:
3. today, I have just opened the guest PC, as in the point #1, and no update available automatically. I pressed a couple of times the button, nothing.
Seems, like I can't work today, because the DBs were already all opened in 8.54 version, and I do not want to destroy them by opening them with 8.53.1 EPIM.
Any clues?
Trinitylab
Re: No update to 8.54 available on Win10
All the day I could not update EPIM on the guest PC, Win 10. Same message, no update avail.
Been thanked: 363 times
Trinitylab, you can get 8.54 on all your computers by downloading from here:
https://www.essentialpim.com/get-epim
the explanation for your case is that we have auto-update to 8.54 turned on for a few hours (when your host PC updated) and then we turned it off as we need some time to regroup and make some changes to 8.54.1
Trinitylab
Hi Max, under the link there is 8.54.1, is it fully ended or being changed?
Has thanked: 779 times
Been thanked: 411 times
Yes, that's the fixed version.
Trinitylab
Thanks. When it will be available through an automatic update?
Trinitylab wrote:
Fri Jul 12, 2019 4:07 pm
We are doing a staged rollout, it will be available in different time to different users, but most will start getting it in a few hours.
Trinitylab
Thank you, Max.
If you are using 8.53.x, you will still need to update to 8.54.x manually, by downloading from https://www.essentialpim.com/get-epim
Trinitylab
Yes, did it, thanks, here it is how a user can see it:
today 8.53.1 host PC recognized there is an automatic update to 8.54.1, I clicked 'download and install', it did, as usually,
then a usual message 'epim will close and restart and bla bla', clicked OK.
Nothing.
Just it closed and did not restart. Two times.
So, yes, I had to do it manually, but this is not how it should be done with the updates. Either, as you said, there is no possibility to make it automatic (devs' failure, but at least with logic behind), or if a software checks, sees, downloads and close itself, it should work to the end.
The same as above was on guest PC, Win10. Done manually, with all the automatic processes not ended.
