Error loop on client sleep wake
MetalDrop
Been thanked: 143 times
Re: Error loop on client sleep wake
Post by MetalDrop »
Made sure the English.lng file was copied over.
New logs attached
error after that.mp4
(479.91 KiB) Downloaded 2 times
Logs.zip
(18.84 KiB) Downloaded 2 times
1st error.png (10.88 KiB) Viewed 74 times
Windows 7 64-bit US-ENG & Windows 10 64-bit US-ENG, Intel i7 7700k, 32GB DDR4, Nvidia & AMD Ryzen 2600 16GB DDR4 Nvidia 1080ti
[I'm helpful and often reply to questions, please note however I am just a fellow user and not staff.]
Has thanked: 778 times
Been thanked: 409 times
Thank you! And another build is ready, same download link, same installation instructions. This one should definitely work :)
Please let us know.
MetalDrop
Post by MetalDrop »
Works in that there is now no more infinitely looping error message so you don't have to kill it in task manager. However it doesn't do anything to avoid some bad potential data loss situations.
Now it simply exits out of EPIM with no chance to recover unsaved work.
Example:
Unplug the network cable to simulate a bump in the network... or other method to simulate other common things.
EPIM now just exits. leaving you with no chance to recover unsaved data in what you were working on.
If you have EPIM set to auto save every 5,10,15,20..etc mins, you just lost up to that much work.
or if you were writing an email, or working in other pop out editors then the working drafts are never auto-saved and you could loss even more work.
TumbleDoor
Been thanked: 11 times
Post by TumbleDoor »
MetalDrop wrote:
Fri Sep 20, 2019 9:43 pm
I got a good laugh out of that since it's so true. One of the offices I use to work at had a terrible IT setup and it seemed like every half hour someone was bumping something that caused a bump/long flicker in the network.
Trinitylab
Has thanked: 12 times
Been thanked: 37 times
Post by Trinitylab »
Oh, does it mean you, guys, are restoring this old behaviour, that on the host, after PC goes idle and is awake, DB is still working?
That would be great.
Which is not entirely true. As information in the database gets saved and updated much more often (almost after any interaction with it).
There's an auto-save feature for email, which is on by default.
Yes, it's working this way now.
All in all, we agree, there's some space for minor and rare potential issues but in order to avoid all that a major update will be required, which we are going to do a bit later down the road.
Trinitylab
Great, thanks.
Trinitylab
8.56 still persists.
Which actions specifically led to which result (error message)?
Trinitylab
I set sleep time to 30 min., walked away just to freeze the host, came back, and tried to use any of the DB opened via server.
And there was a typical message, i do not remember which one, honestly.
The difference though is that I can 'use' DB, for example open a new event in Calendar, but with every click I get this error message (it's the same when PC goes idle with DB opened via the server, and then you want to use DB after awake).
Would appreciate if you make a short video demonstrating the problem and then share a link to it. Thanks!
Trinitylab
Admin, I will try, but I do not want to install the soft you suggest, too many additional co-installing work.
Trinitylab
@admin, just after freeze you can see a 'regular' message like below
When did the "freeze" occur?
Will the message be gone after clicking on the OK button?
Trinitylab
1. Freeze, after the host goes idle.
2. Would have to check, what happens, but definitely is not gone, some other messages pop up.
