Error loop on client sleep wake
Has thanked: 779 times
Been thanked: 411 times
Re: Error loop on client sleep wake
Thanks, will investigate further.
Here's the fixed version: www.essentialpim.com/download/temp/Esse ... roPort.zip
Please check it out and let us know. Thanks!
MetalDrop
Been thanked: 143 times
Post by MetalDrop »
admin wrote:
Wed Oct 09, 2019 6:12 am
It seems to fix the error loop after a long sleep....
However it introduces a strange issue with other programs that use hotkeys.
I'm going to use TinySpell+ as my example since it's the easiest for me to show:
http://www.tinyspell.com/
[A very useful everywhere as you type spell checker which I use for everything to avoid needing custom dictionaries for a bunch of different programs.]
In any new notes created with this version when you correct a word with tinyspell+ it throws you back up to the top of the note:
[See attached video]
This only happens with this version. If I replace it with the current Normal RC2 and the behavior goes back to normal.
In the video I add a bunch of returns to get lower in the note then use the hotkey after misspelling a word.
As you can see the moment I use the hotkey which is [right shift] to bring up the list it takes me to the top of the note.
In the second part of the video I do this again with the current normal RC2 build and it works properly.
This new bug seems to effect many programs [though not all I was able to find a couple of exceptions] that uses a hotkey to bring up a 3rd party menu/window.
Programs I use that are effected by this include:
My screenshot tool
My clipboard manager
My special characters tool
My text expander
My text-to-speech reader
Video_2019-10-09_162824.mp4
(113.02 KiB) Downloaded 4 times
Windows 7 64-bit US-ENG & Windows 10 64-bit US-ENG, Intel i7 7700k, 32GB DDR4, Nvidia & AMD Ryzen 2600 16GB DDR4 Nvidia 1080ti
[I'm helpful and often reply to questions, please note however I am just a fellow user and not staff.]
Thanks for the confirmation and for the detailed description of another problem. Here's the fixed version (along with couple of other fixes and improvements): http://www.essentialpim.com/download/te ... roPort.zip. Would appreciate to hear your feedback. Thank you!
MetalDrop
Post by MetalDrop »
admin wrote:
Thu Oct 10, 2019 9:28 pm
The jump to top issue is fixed in the main program.
No error loops after a couple of long sleeps.
The sticky notes are jumping to top:
[see attached video]
They also have the odd added extra effect of putting the input text from Tinyspell, textexpanders, & clipboard managers...etc at the top of the note. Which is a little different then what was happening with the main window.
Video_2019-10-10_193627.mp4
(46.22 KiB) Downloaded 3 times
Thanks for the update! The following build should fix the problem with the stickies: www.essentialpim.com/download/temp/Esse ... roPort.zip
