Bug: Calendar hours scale showing no hours at the end of the day
Trinitylab
Has thanked: 12 times
Been thanked: 37 times
Post by Trinitylab »
newest EPIM Biz. Win 8.1.x 64
See the screeshot:
It worked OK, until now.
In one DB I just wanted to shorten the work hours, and bang. Now cannot get rid of it, no matter what working hours I set at the end of the day, it always does not show the last two hours.
Strangely, same version, same PC, the other DBs work fine.
Setting in Options:
One clue:
for the first time I checked "auto scale...", and this happened after that. No clue if there is a link between.
Any ideas?
Trinitylab
Re: Bug: Calendar hours scale showing no hours at the end of the day
Hi, any messages/confirmation of that?
Been thanked: 363 times
please state your version number, literally.
After you restart you computer, is the issue still there?
Can you reproduce on new database?
Trinitylab
1. Pro 8.63
2. Will tell you. I just changed to 6-21 working hours, and it persists. Will restart, and tomorrow will come back, I hope.
3. Yes, same thing.
However, I noticed that:
if I do it right now, ie. change the working hours by decreasing the end time, there is a bug. But if I close DB, and open any new one, it keeps the new settings correctly, like 6-21, or 6-20. No empty hours. So regarding point #2, I believe there will be no problem after restart. Simply, EPIM does not react promptly and properly to a change, but after reopening, it does.
Trinitylab
After the restart it works OK, ie. shorter hours are displayed properly. I believe a restart of EPIM is enough, so it is a small bug.
Thank you. I was able to reproduce issue on 8.63, but not on 9.0 Beta 1. Thus I guess we can consider it fixed it there.
