Bug: after 8.64 update right side single tasks not displayed
Trinitylab
Has thanked: 12 times
Been thanked: 37 times
Post by Trinitylab »
Hi, the newest EPIM 8.64, Win 10 x64,
After the update tasks in Calendar module (on the right side) look very odd:
In regular Tasks module it looks OK.
Trinitylab
Re: Bug: after 8.64 update right side single tasks not displayed
This works on Win 8.1 though.
Also, I can see that simply task title color has been changed to white.
Been thanked: 363 times
it may have to do with enlarged fonts on your Windows. Just for a test, can you switch back to 100% font size and 100% dpi- and restart EPIM- will it bring everything to the norm? It may be the reason why Win 8.1 displays EPIM correctly.
Trinitylab
OK, did it, set to 100% and came back to 175%, because 100% is unusable with that resolution.
So now I can see the tasks, text is black again, but still something is wrong:
Has thanked: 778 times
Been thanked: 409 times
This should be fixed in the latest update (8.65 version). Please check it out.
