Going from free version to pro
- Has thanked: 820 times
Re: Going from free version to pro
In most cases you do not need to do anything special. Pro will find your database.
If you want to be on the safe side, before updating, go to FIle-> Database Management and write down the Path to the database. If Pro version does not open your database automatically, you will use File-> Open menu to navigate to your database.
