EPIM Pro Net does not open database
akapune
Post by akapune »
I made a fresh install of EPIM Pro Network 3.04 on an XP (SP3) machine. The Firebird Server is running and EPIM works so far. The database resides on the same machine. But I have the following problem:
When I start Windows EPIM gets automatically started too. But EPIM does not automatically open my database (127.0.0.1:C:\Dokumente und Einstellungen\root\Anwendungsdaten\EssentialPIM Pro\Albert1_2009_07.epim). I see the attached screenshot.
However, if I start EPIM manually then my database is opened. Here is an excerpt from EPIM.INI:
[Files]
1=127.0.0.1:C:\Dokumente und Einstellungen\root\Anwendungsdaten\EssentialPIM Pro\Albert1_2009_07.epim
2=test.epim
OpenFile=127.0.0.1:C:\Dokumente und Einstellungen\root\Anwendungsdaten\EssentialPIM Pro\Albert1_2009_07.epim
LastDir=
LastExportDir=
LastImportDir=
What can I do?
Thank you and kind regards
Albert
Error message
Error message
Re: EPIM Pro Net does not open database
My first guess would be that Firebird starts after EPIM when Windows loads.
akapune
Post by akapune »
Hi Max,
This seems to be the solution. I checked the Firebird Service and found that it started manually. Changing the settings to automatically works – at least until now :) .
Kind regards
Albert
