1. I am a lone software developer, have two machines and a number of Virtual machines. Can I buy just the network version and pay for a single user and be able to install the client in each of my locations? Of course there's only one of me so I would only log on from one location at a time.
2. I read here about installing on a ubuntu server. Is that possible on a desktop version of ubuntu? I'm not a linux expert by a longshot. I just installed Ubuntu last week and put one of my vm's on it and they run noticably faster than on Vista.
New User network
- Has thanked: 820 times
Re: New User network
1- yes, you can, but if you are alone using it, what's the need for this? Desktop version can open database files on local disks, so you could use Desktop in each installation?
2- Yes, you could do it. Here is how people did it:
viewtopic.php?f=31&t=6743&p=33933&hilit=ubuntu#p33933
I was hoping to keep global information in the database that would be usable in every one of my environments -- eg website logon information, links, to-do's, code snippets, etc., I only need to access them from one environment at a time. I would not like to switch to the host for example to get the todo list for the program I'm working on. I don't see how this can be done without the network version.
Suppose you install EPIM in all systems you use. You put database on one of the local disks that's accessible from any system you use. You boot in one system, use EPIM, close it. Boot into another system, use EPIM (same database), close it. What looks wrong for you in this?
