I am able to synchronize my Schedule, To Do, and Contacts. But, when I try to sync the Notes, I get this error dialog:
Outlook Synchronization Error - Notes
EPIM Pro 3.21 Desktop Network
Windows Vista Home Premium SP2
Re: Outlook Synchronization Error - Notes
MS Outlook Pro 2003 (11.8313.8221) SP3
- Has thanked: 820 times
I could not reproduce this on my test 500+ Notes database..Is there any chance we get to look at this database without any other data beyond Notes?
MOst probably there is one particular Note that's causing this, but not sure how to find it.
Sure, Max. I don't have any problem with sending it. Give me a while to purge out everything else, and then decrypt it. I'll then attach it to a PM.
I've been getting an "Invalid Pointer" dialog, too. And, since I'm networked with the wife's PC, she has been getting these errors on her machine, also.
I'll send the data in a bit.
Database, with Notes only, sent in PM.
HI,
just to confirm, we reproduced the problem, will fix.
Many thanks!
