自4.01后至5.54,日期显示中的天数从没正常过,help
中文语言的讨论和支持
panayi
Post by panayi »
OS系统用过windows7-home简体中文版,windows7旗舰中文版,windows7pro英文版
创新新记录时,如今天日期为2013-5-11,则只能看到2013-5-1,不知后面是10或13或19等,极为不便
4.01在同一系统中正常
panayi
Re: 自4.01后至5.54,日期显示中的天数从没正常过,help
Post by panayi »
5.56了,仍是没解决这问题。。。
中文用户们? 你们的都没这现象么? 请贴个图出来看看。
Been thanked: 363 times
looks like you are using non-standard DPI in your Windows settings.
panayi
Post by panayi »
现在5.81了,仍是不能正常显示完日期
In the screen above I think you are using increased Windows DPI. In this case it is expected if some information does not fit.
panayi
Post by panayi »
panayi
Post by panayi »
使用中文的用户,在windowsXP和windows7和Windows8时,都出现这个同样的问题,日期显示不完整。
其他中文用户也是一样的。你可以询问其他的中文用户, 请给予解决,谢谢。
OK, thank you. Can you try 5.81, is the problem there?
panayi
Post by panayi »
最新的5.81,也是一样的,看不到完整的日期。
我问过,很多的中文用户,从4.01后, 都是看不到完整的日期。
panayi
Post by panayi »
5.82 no ok.
Why do you have so strange date "2014 /7/17"? Isn't it "2014/7/17"?
panayi
Post by panayi »
为什么不能增长一些显示日期的窗口? 我试了很多台不同的中文电脑系统,都是看不到完整日期的。
(您可以询问其他中文用户,他们也是看不到完整的日期的,很不方便。)
Why can't we grow some window display date?I tried many different Chinese computer systems, is can't see the complete date.
(you can ask other Chinese users, they also can't see the complete date, very inconvenient.)
Thank you. We will try to increase space on all fields you posted on the screenshots in next 6.0 version. If there are more, please post them here.
6.0 version will have all those fields enlarged.
panayi
Post by panayi »
Max wrote:6.0 version will have all those fields enlarged.
我没有6.0的版本, 什么时候可以公开下载到啊,很想尝试, 谢谢。
