Epim Today date format
Delboy
Post by Delboy »
Is there any way I can change the date format on Epim Today on the free version ?
It's in British format elsewhere on the program IE; "day of the month,month,year" but on Epim Today the date shows in American format IE; "Month,day of the month,Year"
Cheers,
Del.
PeCe
Has thanked: 86 times
Been thanked: 274 times
Re: Epim Today date format
Post by PeCe »
In general EPIM follows the settings of your computer, but sometimes it is inconsistent. Often this is a windows problem.
Maybe you can try the solution I described in the following topic; viewtopic.php?f=2&t=9809&p=41104
I think after doing this the problem should be solved.
EPIM Pro portable 9.8 / Android EPIM 5.8.1
Delboy
Post by Delboy »
Thanks for the reply PeCe.
I read that post before posting my question, I'm afraid it didn't help.Thanks for trying though.
Del.
Delboy
Post by Delboy »
Hi again Peter,
I've had more time this morning to play around with your suggestion, just changing the location and format in itself didn't work so I also changed the short date format,saved it then changed it back to my preference and saved again,I rebooted the machine,loaded EssentialPim and bingo date format is now perfect.
So basically your suggestion does work.
Thanks very much.
Derek.
