Signature
Signature
update needed please. allow for pre-defined signatures and original user made signatures either or not both (on epim free.) not here in the forum
Windows 10 Home 1607 64 bit
EPIM Free 7.11
EPIM Free 7.11
- Has thanked: 2 times
- Been thanked: 60 times
Re: Signature
Hello.
I do not know if it works under Epim Free but try this:
Tools\Account settings
Select your account
Edit button
Signature Tab
If you are a new comer, I would recommend that you navigate in http://www.essentialpim.com/help/
It is a good tutorial.
Select your account
Edit button
Signature Tab
NormTheStorm
Win10 Home Version 22H2 (OS Build 19045.4170) 64-bit, 8 GB RAM, EPIM Pro Life 11.8.4
Re: Signature
I see sign message is only on pro. is that different or the same thing as "signature..." (edit) (I guess I could always manually enter a signature.)
EPIM Free 7.11
EPIM Free 7.11
Re: Signature
I don't use the free version so can't say much there, but this is how the Signature system looks/works on pro.
Pretty much you can set an outgoing signature for each mail account, and I'm pretty sure that's pretty much it. I don't use it myself as I don't want a generic signature being sent on everything I send. It would be much more useful if the mail rule system had an attach signature option so you could setup rules for signatures to only be attached to specific messages.
Re: Signature
I agree with you MetalDrop.
I do not use a signature either as I was stuck to remove it because not needed most of the time.
It would be nice to create one and have it available under Insert\Signature in the menu of New Message window.
NormTheStorm
Insert Signature
it actually sounds to me that the insert signature in the new message window would be a good idea. But I need to be able to make my own signatures? Is that possible in the free version if there is an update?
EPIM Free 7.11
EPIM Free 7.11
Insert Signature
it actually sounds to me that the insert signature in the new message window would be a good idea. But I need to be able to make my own signatures? Is that possible in the free version if there is an update? trial version works for only 30 days....i did not know free meant trial? what is this...goodness
EPIM Free 7.11
EPIM Free 7.11
Re: Insert Signature
I went and downloaded the portable version of the free version and the signature system is the same in it as pro.joelkevinbaker wrote:it actually sounds to me that the insert signature in the new message window would be a good idea. But I need to be able to make my own signatures? Is that possible in the free version if there is an update? trial version works for only 30 days....i did not know free meant trial? what is this...goodness
Once you make an account simply go back and edit the account Main Menu > Tools > Account Settings > Select and account > Edit > Signature.
P/s
There are two version of EPIM
- Free with a small ad that is always free (Note the ad moves around the interface a bit so I can't say exactly where it is but if you do not see the ad you are not using the real free version.)
- Pro Trial which is free for a limited time, if you want always free make sure you are downloading the one marked as such.
Examples of the ad to look for:
