[SOLVED] [7.22] Changing date format?
littlebigman
Post by littlebigman »
Hello
I'm trying 7.22 on Windows 7 and Android 6.0.
I chose US/English as the system language because it's easier to get help in case of a problem, but as I'm located in France, I want dates to be DD/MM/YYYY: Currently, EPIM shows dates as MM/DD/YYYY and I found no option in Calendar's Settings.
Can I change this without having to set Android to French?
Thank you.
MetalDrop
Been thanked: 189 times
Re: [7.22] Changing date format?
Post by MetalDrop »
On the desktop version you can change the date format in:
MainMenu> Options > General > Date and time formats
You can then uncheck "use system defaults" and change the format to how you'd like.
As for android 6 the best way to do it would be to change your system language to English UK rather than English US.
Go to settings > Language & input > Language > English (United Kingdom)
littlebigman
Thanks for the work-around.
