Good morning.
Please can you find out if there is a solution to this problem? I receive emails regularly, but no longer sends the email, gives the message of completed message but the email remains in the "outgoing mail" folder and is not shown in the mail sent. If I try to change the parameters in the account configuration box (smtp, pop3, server etc) the program crashes. If I create a new account with the same domain and using the same parameters for pop3 and smtp everything works regularly. I await your kind reply as soon as possible. Thank you so much
Epim portable version 6.58
S.O. Win10Pro64
problem with sending emails
Re: problem with sending emails
P.S. I also tried to open the db .epim with a newer version (7 and but the result is the same
Please use the latest version (8.52) and change SMTP settings. If still does not work- please post screenshots of your SMTP settings and of the email in oubox.
