Sync Problems: Calendar and Contacts
NoteIILTE
Re: Sync Problems: Calendar and Contacts
Post by NoteIILTE »
Dear Admin,
Thanks for the quick response. Since the size of the sample DB is over 2 Mb (maximum allowed size for the upload via this forum), I've zip it using 7-zip. Please unzip it to extract the sample db.
Please note that the entry under group "Friends" is the original one and the one not belonging to "Friends" is added by the sychronization process.
William
test.zip
(203.96 KiB) Downloaded 148 times
Has thanked: 934 times
Been thanked: 554 times
William, thanks, confirm the problem. Will try to fix.
NoteIILTE
Post by NoteIILTE »
Dear Admin,
I've encountered a new problem and I would report it here:
After each sync, the 2nd and 3rd entries of the speed dial setting were erased and I had to re-assign them. It seems it has something to do with the synchronization process.
William
William, thanks for the report. Did you edit these contacts in between synchronizations?
NoteIILTE
Post by NoteIILTE »
That's what I thought but I did not edit thoses contacts in between.
William
Very strange, then. We aren't able to reproduce the issue on our side. May I ask you to do the following:
- close your existing database file in EPIM
- create a new one
- synchronize your phone with the new database
- synchronize couple more times
Will you experience the same problem with contacts being removed from the Speed dial setting on your phone? If yes, please post a log file here.
NoteIILTE
Post by NoteIILTE »
What does it mean by creating a new DB, does it mean a copy of the existing DB? I am hesitated to create a brand new db with only a few entry such that the entries in the phones will be wiped out?
I am attaching a log file for the time being.
William
AndroidSync_2013_01_19_19_31_30.log
Log Files
(8.24 KiB) Downloaded 145 times
No, you need to create a new database file (File->EPIM Data File). Don't worry, nothing is going to be wiped out if you use a 2-way sync process with the default settings.
NoteIILTE
Post by NoteIILTE »
Dear Admin,
It seems that I could reproduce the problem. You see, in addition to synchronizing the contacts with Androiod, I also sync them with iPad (IOS4). If I sync both at the same time, the 2nd and 3rd entries of the speed dial on android would be erased. If I only sync with Android, the entries would be kept.
See if you can reproduce the same.
William
What your iPad is synchronizing with? Thanks.
NoteIILTE
Post by NoteIILTE »
admin wrote:What your iPad is synchronizing with? Thanks.
The same EPIM database on the desktop via WiFi also.
William
Interesting.. will try to reproduce and fix. Thanks.
