Some serious privacy concerns
Has thanked: 780 times
Been thanked: 411 times
Re: Some serious privacy concerns
Likely the app needed to check for your registration info, if you're a Pro version user.
lk
Has thanked: 11 times
Been thanked: 5 times
Post by lk »
I'm a Pro user of the PC version, my Android version is the free version. (Can I upgrade to the Pro version without a Google account?)
If the option to opt-out of Google snooping does only work for the Pro version, you should grey-out or remove this checkbox in the free version. On my phone (Android 5.1), this option currently looks like a placebo (which could possibly violate GDPR, but IANAL).
(It's a real pity that you gave up your former privacy-friendly approach at some time!)
lk
The option for sharing analytics data works as for the Pro as fro the Free versions. Were there any other requests to outside IP addresses except for the very first one after the update?
lk
Post by lk »
Yes, there were. One request every few hours.
lk
a8907433
Been thanked: 115 times
Post by a8907433 »
Hello ik!
Yes, there is. I use my smartphone with deactivated Google playstore, Google services and so on. I wrote an email to Astonsoft Support, how to pay, and how to activate AEPIM pro, they told me. Do the same!
Thanks! Will double check whether there's any remaining and unaccounted for requests left in the code.
