Hey there,
after using epim for some time and searching the forums, i am wondering if i am the only person, who is affected by the following bug/problem:
In my calendar i am setting appointments with a (standard) reminder of one hour in advance and two, three or more daily recurrencies.
The first reminder of these appointments gets triggered as planned, one hour before the appointment,
the reminders on the next days get triggered ONE HOUR AFTER the scheduled appointments!
When i started using epim, i did not notice this strange behaviour. In my opinion it started after an update a couple of months ago.
Does anybody experience similar problems or know a solution for them?
Thanks for any help
epimpro 5.1, essentialpim 7.24 on win 8.1, android 4.4.4, timezone: GMT +02:00
Calendar - reminder alarm of recurrent appointments
Re: Calendar - reminder alarm of recurrent appointments
You mean there's just a single reminder that should come up 1 hour before each of the recurring appointments? What happens with the first reminder when it sounds - does it stay intact or you dismiss or maybe postpone it? Thanks!
Yes, i use only one reminder, the standard one from the calendar settings, after notification i dismiss it.
Confirm the issue, will be fixed in the next version of the app.
Thank you very mucho,
looking forward to the fix.
