Sorry, but there are numerous problems syncing notes with Windows 7.54 and newest android version.
You name is, sometimes images don't' sync to google drive, sometimes notes don't sync. Notes on android are different that the same name note on Windows.
I was hopeful but notes are just a big problem.
I created a note in Windows with a few images, synced it, it worked ok. Then the images were gone. They were on the android but they were no longer on the Windows laptop.
I could go on. But I did give it another shot upon seeing the new versions and updates.
I even tried the new windows beta 7.6 no syncing of attachments etc.
New android version New Windows still problems
- Has thanked: 1418 times
Re: New android version New Windows still problems
We recommend to use the latest EPIM Beta versions on both sides as on Window as on Android. That would be Android EPIM 5.3 Beta1 and Windows EPIM 7.6 Beta3. If something's not working between these two, please do the following:
1. Describe the problem in as much details as possibly (preferably include a list of steps)
2. Forward us the log file.
- johncesta
- Has thanked: 1 time
- Been thanked: 10 times
I am using the latest betas on both sides. The steps are simple. I add notes and attachments to the windows laptop and sync to google drive. Sometimes the notes appear sometimes not. Sometimes the note appears but the image does not appear. Attachments have never appeared.
I add notes to the android side. Sometimes they appear on the laptop. Sometimes a day later. Attachments never sync to the laptop side. Sometimes images included in the note appear, sometimes they don't. Sometimes they appear and I think everything is ok then later after some routine syncing the image in the note on one of the devices it gone but it's still on the other device.
Sometimes if I add a note to the laptop with an inline image and sync it sends ok to the android. Then on the android if I edit the note and change the image and sync I'll have one note on the android with the new image but the note on the laptop still contains the old image. And no matter how much syncing this situation never changes.
I ran out of time to keep trying. I have to just use epim for it's other strengths: tasks, calendar and contacts and am using nimbus notes for notes.
John
John
John Cesta
Knights of Columbus
Knights of Columbus
Thanks but we will not be able to address the issues you're having unless we see the sync log files. For instance:
We're unable to reproduce the problems on our side. Forward us the latest log file when either of the cases happened. Would check it in order to get to the cause of the issue.I am using the latest betas on both sides. The steps are simple. I add notes and attachments to the windows laptop and sync to google drive. Sometimes the notes appear sometimes not. Sometimes the note appears but the image does not appear. Attachments have never appeared.
How do you sync Android and Windows versions of EPIM with each other? Would that be a direct sync or via Google Drive?I add notes to the android side. Sometimes they appear on the laptop. Sometimes a day later. Attachments never sync to the laptop side. Sometimes images included in the note appear, sometimes they don't. Sometimes they appear and I think everything is ok then later after some routine syncing the image in the note on one of the devices it gone but it's still on the other device.
- johncesta
I only ever sync with google drive.
Here's what I did today:
1. Uninstalled epim from android tablet
2. Reinstalled and synced with google drive notes appeared but attachments didn't appeart
3. So I created a new note in Windows 10 included a small image and an attachment
4. I synced that note to google. The note and attachment and image made it to google drive
5. I synced the tablet. That note was not on the tablet.
I've included some images for your review:
One is the new note on windows 10
One is the note and attachment on Google drive
another image is the android tablet with no note, image or attachment
I've included the windows log file
John Cesta
Knights of Columbus
Knights of Columbus
Thank you! I can confirm that notes attachments are not yet synchronized between Google Drive and Android EPIM. This feature will be added into the 5.3 Beta2 version of AEPIM.
- johncesta
Ok, so as you can see Not even the note was synced to android from google. Does that mean that if the note has an attachment not even the note will be synced to android yet until the new beta?
I understand.
I understand.
John Cesta
Knights of Columbus
Knights of Columbus
Notes should be synchronized in any case. Will check the situation out and improve in the Beta2 version.
