I am looking for functionality similar to a smart list, which is basically a saved search with multiple parameters. For example: I want to search for all tasks with tags "FILMING" and "CAR" and location "PRAGUE". Firstly I would like to be able to execute such search at all (or at least multiple keyword search) and secondly I would like to save it so I can quickly get to its results any time I want. This would basically give me the smart lists capability. So far i don't think it is possible. if that's correct than it is a shame, because tasks have multiple parameters and not being able to search tasks using these parameters makes little sense IMHO. Hopefully I am wrong and the above mentioned functionality is hidden somewhere?
Thanks in advance!
Best regards,
Karel
Smart list/Search capabilities
- Been thanked: 1 time
- Has thanked: 2 times
- Been thanked: 60 times
Re: Smart list/Search capabilities
Have you ever tried in the menu Tools\Advanced Search and Advanced Tab ???
It seems to fit your need.
NormTheStorm
Win10 Home Version 22H2 (OS Build 19045.4291) 64-bit, 8 GB RAM, EPIM Pro Life 11.8.4
thanks for your reply. I have googled this, but never found it in the app. I cannot see neither any tools menu nor any advanced search on android.
Sorry I did not notice the question was for Android.
Hope you will find your answer.
NormTheStorm
no problemo
Still hoping someone could help me with my original question?
K
K
- Has thanked: 1418 times
There's no such functionality, as of yet. However, I agree that the suggested feature might be very useful, therefore will add it into our internal to do list for implementation in the future versions of the app. Thanks!
