Do notes sync reliabily for most of you?
- johncesta
- Has thanked: 1 time
- Been thanked: 10 times
I've been at this for over a year. Installed all the new updates betas etc and still notes do not sync reliabily if at all.
Today I tried again with all the new versions. I synced on my 7.0 android tart and managed to only get 3 of the over 10 folders on my google drive.
I added a note on my tablet with an attachment and an image. It doesn't sync to my phone.
I uinstalled the app on my tablet and started over. It synced the 3 folders of the 10 from Google but in one folder duplicated a note about 3 times. Don't know why.
It simply doesn't work.
I've read where other companies have problems syncing to Google drive and have gone elsewhere to sync.
I also have many other apps that sync to Dropbox and onedrive and they all work pretty well.
Also, I have a few apps that sync to their own servers and these all work perfectly.
I think epim should consider changing their model and go somewhere else to sync notes
Or perhaps I'm the only one out here who has had consistent sync problems with Google drive and maybe I should just shut up and give up. Or give up and shut up. Either way.
John
John
John Cesta
Knights of Columbus
Knights of Columbus
Re: Do notes sync reliabily for most of you?
I do not sync anything. I have my data portable- that´s enough. I try to sync from time to time...... but this does not work reliably. Perhaps I would sync from my computer to my mobile- some time, when it works really and reliable.
- PeCe
- Has thanked: 101 times
- Been thanked: 329 times
I only sync one-way from the laptop to my 4.2 tablet and 7.1 smartphone. In earlier 7.0 versions of WinEPIM I had problems that not all notes were synchronized, but nowadays it works okay again. I don't know which version corrected the problem, but synchronizing notes works okay from laptop to mobile.
I do not use dropbox, google or owncloud to synchronize.
Please mention your current AEPIM version, so that we are sure you really do have the latest one.I've been at this for over a year. Installed all the new updates betas etc and still notes do not sync reliabily if at all.
What do you mean by saying "all the new versions"? There's only one version of Android EPIM.Today I tried again with all the new versions. I synced on my 7.0 android tart and managed to only get 3 of the over 10 folders on my google drive.
Do you see that note on the Google Drive if you check it out using a web browser?I added a note on my tablet with an attachment and an image. It doesn't sync to my phone.
If there's any problems, we'd love to fix them. But we need to get more info about the problems first. Thanks!
Downloaded and installed epim windows free 7.62 and android 5.3.5. Sync successful, but notes do not appear in correct order after manually re-ordering in either platform.
Oder of notes will not be synchronized. We plan to add this feature in one of the upcoming new versions. Thanks!
Every time my phone syncs it duplicates the note. I ended up with the same note about 10 times on my phone. This is one reason I stopped using the Android app.
We would like to see the log file, it can be found here: Tools->Options->Synchronization, Browse... You might also want to clear up Android sync data from File->Database Management, usually that helps. Thanks.
- johncesta
I tried all those things with regard to syncing to google drive.
I spent untold hours and days and weeks trying to manage to get it to work. I consider myself an advanced computer user.
I had newest version on all platforms, I checked google drive to see if files and folders were present, I purged the devices and started over, and over, and over.
Never worked right. Drove me crazy. I left epim for a year.
I came back to epim and used the wireless syncing for my PC, TABLET, and PHONE and it all works great now.
J
J
John Cesta
Knights of Columbus
Knights of Columbus
I synchronized my PC with tablet, with the newest version (8.02) over EPIM Cloud. One Way (EPIM > Cloud, Cloud > EPIM). Suprisingly, that worked without any bug!
I wished, EPIM Cloud would work for AEPIM too.... I never will use Google Cloud or another Cloud service, which is payed with my data (instead my money).
This will be implemented in the future. Thanks!
