Bug: no background sync, again
Has thanked: 780 times
Been thanked: 412 times
Re: Bug: no background sync, again
It seems the one that syncs with Android was simultaneously opened in two EPIM instances as in this case the same port cannot be used twice and hence the error message for the second copy.
Trinitylab
Has thanked: 12 times
Been thanked: 37 times
Post by Trinitylab »
Hi admin, was checking this for a couple of days, no, one instance, same problem.
Actually, syncing with Android is the weakest point in EPIM, unfortunately.
If the port number is in use, you can always change it to another one in the sync settings.
Trinitylab
Still the message, one instance working:
Still need to see the log file. Thanks.
Trinitylab
Hi, have just sent in PM, hope you receive it.
Got it, thanks! This will be fixed in the next release of AEPIM.
Trinitylab
Great, thank you!
Trinitylab
Hi, in 8.55 BE something improved, several background syncs occured, and now all is back to 'normal' :)
The issue needs to be fully fixed on the AEPIM's side.
Trinitylab
Thanks!
Very much. 10+ characters used.
Trinitylab
8.62.1 Biz
Still huge problem with sync with Android. Ie. no sync at all, manually, in background.
One DB working.
Honestly, this is a big bug, for more than a year I cannot rely on automatic DB syncing. Also on manual.
You should have done something with this. Today having the same stuff on a desktop and in a smartphone is obvious.
What's the error message (if any)?
