Task created with wrong date
marmegint
Post by marmegint »
I use EssentialPIM Pro v5.6.2 on Android 9 (Pie).
When i create a task eg.:
start: 2019. october 15. (Tuesday), at 11.00 h
end: 2019. october 15. (Tuesday), at 11.30 h
show in calendar
category: Work
alarm: 2019. october 15. (Tuesday), at 11.00 h
repeat: weekly, every Tuesday (no end date)
when i save it, the start date is jump to 2019. october 19. (Thursday) and repeat: every saturday automatically.
The end date/time and alarm is stay original.
To modify to october 15 is not possible.
This also happens on other dates.
Please help me!
What do I do wrong?
Thank you.
Has thanked: 780 times
Been thanked: 412 times
Re: Task created with wrong date
I'm not seeing this happening on the 5.7 Beta 2 version. Would you like to give it a try? Thanks!
marmegint
Post by marmegint »
Yes, i would.
Where can i download the version 5.7 Beta 2?
Thank you.
You can sign up to be a beta tester of the app in the Google Play store (temporarily, if you wish) and then you'll be able to download the latest 5.7 Beta 2 version with this option enabled. Thanks!
