Suggestion : date stamp
henacynflin
Has thanked: 4 times
Post by henacynflin »
Unfortunately Textpand will not work within the notes module. I often create notes with a date and a time stamp. On the PC this is no problem as there is an "Insert Date" option. A similar option on the android version would be great.
Cheers
Alan
Has thanked: 778 times
Been thanked: 411 times
Re: Suggestion : date stamp
Thank you for the suggestion, noted.
