sync error with task repetition set up to more than 99 days
Keldi
Has thanked: 9 times
Been thanked: 35 times
Post by Keldi »
The wi-fi synchronization of PC with Android stopped working with an error:
Code: Select all
java.lang.NumberFormatException: Value out of range. Value:"170" Radix:10
	at java.lang.Byte.parseByte(Byte.java:151)
	at java.lang.Byte.parseByte(Byte.java:175)
	at com.astonsoft.android.epimsync.managers.TasksManager$TaskData.<init>(SourceFile:328)
	at com.astonsoft.android.epimsync.models.Command.<init>(SourceFile:194)
	at com.astonsoft.android.epimsync.managers.CommandManager.processXMLCommand(SourceFile:121)
	at com.astonsoft.android.epimsync.models.AndroidClient.processNextMessage(SourceFile:148)
	at com.astonsoft.android.epimsync.models.AndroidClient.access$1100(SourceFile:40)
	at com.astonsoft.android.epimsync.models.AndroidClient$2.run(SourceFile:560)
I've spent some time trying to figure out what's causing this, until I remembered that I'd recently set up a task on PC to be repeated every 170 days:
I've edited the task to be repeated every 5 months (for the synchronization to work), but I'd rather have the task repeated exactly every 170 days.
Has thanked: 780 times
Been thanked: 412 times
Re: sync error with task repetition set up to more than 99 days
Confirm the problem, thanks, will fix.
