Android shortcuts problem.
lbw2112
Has thanked: 4 times
Post by lbw2112 »
Pro 5.7 RC1
Samsung Galaxy S8
I copied all the section shortcuts on my home screen so I can just go directly into whichever section I need from there. It seems to only work for the first two selections I choose and then it goes into that last screen no matter which shortcut I press next. I can close the program and then I can select whichever section correctly but again with only the first two selections. The one exemption to this is the "sync" shortcut, that always works correctly.
For example, I choose the Calendar shortcut, it goes to calendar.
Later I press the Tasks shortcut. It goes into Tasks.
The next time (third time) I press any shortcut (with exemption of "sync"), it goes into the last screen I was using in EPIM, in case I changed sections while in the app last.
Thanks,
Larry
Has thanked: 778 times
Been thanked: 411 times
Re: Android shortcuts problem.
Will try to improve, thanks!
