Appointment "Notes" field copying problems.
markdate
Post by markdate »
EPIM apk 5.7
Problem appeared after last time actualization apk to 5.7 ver.
Performed actions:
- marking text in appointment title field;
- copying text into buffer;
- pasting copied text to "Notes" field;
Any text copied to buffer is changed to below attached string
com.onegravity.rteditor.api.format.RTHtml@fb745e0
Can I do anything on my mobile to back it to normal action?
Has thanked: 780 times
Been thanked: 411 times
Re: Appointment "Notes" field copying problems.
This is a bug, which will be fixed in the next update. Thanks!
