I find the following manipulations reproducible in all contacts-notes:
- Character "<" change to "<"
- Character ">" change to ">"
- Mail-addresses "a.b@c.com" change to "<front color="#0000FF"><a href="mailto:a.b@c.com">a.b@c.com</a>/front>
The notes in EPIM for PC (!) remain correct. If I renew a contact in EPIM for PC and make a synchroization the text on Android is damaged again.
My contact-list is very long and I need a solution for this problem. Thanks.
Text of contact-notes is damaged after last update
- Has thanked: 864 times
- Been thanked: 483 times
Re: Text of contact-notes is damaged after last update
Confirm this problem, thank you! Will be fixed in the next update.
Next update brings next errors. In the new version 5.7.1 all word wraps (CRLFs) in all contact notes are lost. I'm not amused.
Please post a screenshot showing the problem.
The problem is not understandable? Here's an example:
The note should be:
- Row 1.
- Row 2.
- Row 4.
- Row 7.
But after the update it is:
- Row 1.- Row 2.- Row 4.- Row 7.
The note should be:
- Row 1.
- Row 2.
- Row 4.
- Row 7.
Confirm the problem, thanks. Will fix.
- Has thanked: 26 times
- Been thanked: 12 times
I confirm the problem. Where there were line feeds - solid text everywhere. This applies not only to contacts, but also to the Password Module.
