Recurring Task moving day with different category
fuzzyfacesteve
Post by fuzzyfacesteve »
I have a recurring task that I have somehow managed to have red text for. While trying to get red text in another task I came across the problem in the subject.
If I change the category the recurring task will change the day it is displayed in the calendar or disappear from it altogether.
What information can I supply to help you look at this?
Has thanked: 863 times
Been thanked: 482 times
Re: Recurring Task moving day with different category
Thanks for the info, I think we were able to nail the bug, will try to fix it in the next update.
fuzzyfacesteve
Thank you.
