if I tap the "complete" checkbox by and then "undo" to revert the action, the task oes not re-appear, IOW is not visible immediately.
Task invisible after completion is undone
- Has thanked: 864 times
- Been thanked: 483 times
Re: Task invisible after completion is undone
You say "not immediately" but it does get visible eventually?
yes, the task re-appered after changing the view, e.g. switching between lists or even close and re-open the task view.
BTW: It happens only if "display completed" (in German; Erledigte anzeigen" is off. If display completed is on, the task re-appears immediately.
Could you please also mention your Android OS version number and the device make and model?
We're unable to reproduce this on a device running Adnroid 8. May I ask you to record a small video demonstrating the issue on your side? Maybe we're missing something..
I found there is another precondition ("View By due date") to reproduce this error, therefore I make a new step-by-step description.
BTW: I didn't think it's so much work to demonstrate the problem.
1. Settings:
a) Do not clear completed tasks automatically
b) Hide completed tasks
c) View -> Check "By due date"
These three settings need to be combined.
2. Procedure
a) Tap the "completed" checkbox of a task.
b) Undo
1. Settings:
2. Procedure
b) Undo
Thank you, can confirm the issue now. Will be fixed in the next update.
