Good afternoon.
I have AEPIM PRO 5.7.3 installed on a Huawei G8
I have activated the phone's fingerprint detector, and the screen is unlocked with my fingerprint.
However I can't find how to make AEPIM unlock with my fingerprint.
Am I missing any procedure?
Thank you in advance for your help
How to activate the fingerprint unlock
- Has thanked: 864 times
- Been thanked: 483 times
Re: How to activate the fingerprint unlock
Please check if the "Use fingerprint to unlock" feature is activated in Menu->Settings->Passwords.
I have activated the password to protect the entire program. But the option "Use fingerprint to unlock" is disabled. I cannot check or uncheck the checkbox.
It looks like EPIM is not able to determine whether the fingerprint sensor is available on a system level. Please check if EPIM has all the permissions enabled for it. And also mention your Android OS version. Thanks!
I've reviewed the list of permissions the app has, but it doesn't mention anything about the fingerprint.
Android version is 5.1
There's no special permission for fingerprints. Are all of them enabled?
