EPIM Android sync EPIM Pro destroying tabulations
Has thanked: 864 times
Been thanked: 483 times
Re: EPIM Android sync EPIM Pro destroying tabulations
We can adjust the process so that the spaces are kept, although not sure if we should convert tabs into spaces, since some strict formatting will be definitely lost.
Laurent C.
Post by Laurent C. »
I understand
That's why I propose you to just add a formatting option for synchronizing Notes to/from Android at least
:arrow: "Convert tabulations to <ENTER NB TABS> spaces (0 to keep spaces)"
So as to please every clients at the end... : -)
And this will also inform everyone of the tricky difficulties in the future when creating the sync
Regards
EPIM Pro 9.6.1 + EPIM Android on SGN9 / W10 Pro 64 FR + Office 2019 Pro / CPU 3950X + Z63 / GPU RTX 2080 Ti + G12 + H55 / CM Crosshair VIII Impact / SSD 2TB PCie 4.0 5000 MBps + HDD 3TB / 32GB DDR4-3600-CL16 Trident Z Royal Gold / NZXT H210i + RGB HUE 2
Got it, thanks, will probably do something in that regard.
Laurent C.
Thank you very much :D
Laurent C.
Please, do something
When I enter that :
a b c
aa . bb . cc
it is changed to that :
abc
aabbcc
:shock: Aaaaaah !!!
Laurent C.
admin wrote: Mon Aug 24, 2020 8:34 pm Got it, thanks, will probably do something in that regard.
Hi, nothing has changed with EPIM 9.5 : very very annoying behaviour :( ... Regards.
Laurent C.
Nothing better with EPI 9.5.2 :oops:
Laurent C.
Seems not done with release of EPIM 9.6.1 PC :roll:
Laurent C.
Android EPIM 5.8 : Not fixed = I'm waiting next AEPIM version... Regards.
