EPIM Android Back button not working as expected for notes
Laurent C.
Re: EPIM Android Back button not working as expected for notes
Post by Laurent C. »
This is absolutely not a duplicate : please read :D
EPIM Pro 9.6.1 + EPIM Android on SGN9 / W10 Pro 64 FR + Office 2019 Pro / CPU 3950X + Z63 / GPU RTX 2080 Ti + G12 + H55 / CM Crosshair VIII Impact / SSD 2TB PCie 4.0 5000 MBps + HDD 3TB / 32GB DDR4-3600-CL16 Trident Z Royal Gold / NZXT H210i + RGB HUE 2
Laurent C.
Not corrected in Android after release of PC EPIM 9.6.1 :roll:
Has thanked: 864 times
Been thanked: 483 times
How could anything be corrected on Android after release of EPIM on another platform?
Laurent C.
I perfectly understand that, but I presume that if EPIM PC is updating a lot of time, the EPIM Android should not be abandoned : no fixing since July 2020 :cry:
Have you had a chance to check the recently released 5.8 version?
Laurent C.
The recent Google version today is 5.7.4 ...
Laurent C.
Android EPIM 5.8
It works - all works and translation is correct
Except : when I modify a note, use Cancel/Annuler to stop, but click inside the note a 2nd time, and use the Android back button, then it forces a saving again while displaying Note saved/Note enregistrée :wink:
Regards
Unable to reproduce this. Please record a small video showing the issue.
Laurent C.
Hi
I can’t download the video in Attachments : ERROR / File too large: 20210113_111454.mp4
It is written : If you wish to attach one or more files enter the details below. You may also attach files by dragging and dropping them in the message box. Maximum filesize per attachment: 10 MiB.
However, my film is 3 MB only, and yet above the ERROR !?
Regards
Please post it to some online file storage like Google Drive and share the download link.
Laurent C.
admin wrote: Wed Jan 13, 2021 9:01 am Unable to reproduce this. Please record a small video showing the issue.
You're right : I was lucky the very 1st time, as it is not so easy to reproduce, because it happens 1 time out of 5 trials...
Here the video
I try at the beginning of this video without success with my first note while testing
In the end, it happens with "Note enregistrée" after "Annuler" and Android "Back button" :mrgreen:
20210113_111454_50%.mp4
(476.33 KiB) Downloaded 4 times
Thanks, will check this out and fix.
