Today's tasks in Android
bobmac1547
Post by bobmac1547 »
Trying to see just today's tasks in Android version. Can't find a way to do it.
Can someone help me with this?
Using Android 5.7.4 with Android 9.
If you've seen one Parkinson's patient, you've seen one Parkinson's patient!
Has thanked: 863 times
Been thanked: 482 times
Re: Today's tasks in Android
You cannot filter the tasks out so that only today tasks are visible. Although, you can sort by either due or start dates and you can also use the "By due date" view, which allows you to collapse sections of tasks, leaving just the today's ones visible.
bobmac1547
Thanks. That helps, but an explicit filter would be better.
Will add this as a suggestion into our internal to do list. Thanks!
glenn59
Has thanked: 32 times
Been thanked: 14 times
Post by glenn59 »
+1 for "Today's tasks" filter.
EPIM Android Pro v5.7.4 -Samsung Galaxy S5(SM-G900V) - Android OS v5.0
EPIM Portable Pro V6.0 RC2 - Windows 7; XP
EPIM Desktop Pro V8.64 - Windows 7
Volodymyr
Has thanked: 25 times
Been thanked: 12 times
Post by Volodymyr »
