EPIM Android - Impossible to add a contact from Phone app
Laurent C.
Post by Laurent C. »
Hi
Seems you forget to register EPIM Android in apps authorized to add contact after a call using recent calls...
Regards
EPIM Pro 9.6.1 + EPIM Android on SGN9 / W10 Pro 64 FR + Office 2019 Pro / CPU 3950X + Z63 / GPU RTX 2080 Ti + G12 + H55 / CM Crosshair VIII Impact / SSD 2TB PCie 4.0 5000 MBps + HDD 3TB / 32GB DDR4-3600-CL16 Trident Z Royal Gold / NZXT H210i + RGB HUE 2
Has thanked: 864 times
Been thanked: 483 times
Re: EPIM Android - Impossible to add a contact from Phone app
It should be EPIM Android's account, not the app itself.
Laurent C.
Hi
No, it's not
If I install another app for managing contacts, the app resisters itself to be able to create new called numbers in Android contacts
It's not the case with EPIM ; and only EPIM is concerned so far... :?
Regards
Laurent C.
Hi, what is the status since EPIM 9.6.1 please ?
