EPIM Android - Contact systematically saved even if no change
- Laurent C.
- Has thanked: 3 times
- Been thanked: 1 time
Hi
1/
When a contact is open for editing by mistake and no data is changed, the back button forces a saving
Is shall not do that, but just cancel the editing
This causes false modified date change and contact is falsely propagated through all syncing although nothing was changed...
2/
The French wording is also not good
"Jeter" shall be changed to "Annuler" because "Jeter" means throwing the contact to the trash...
"Effacer" shall be changed to "Supprimer" because "Effacer" means to empty the contact content before writing something else inside...
Perhaps you should consider to change "Jeter" & "Effacer" false terms in all the modules of your app...
Regards
1/
2/
Regards
EPIM Pro 9.6.1 + EPIM Android on SGN9 / W10 Pro 64 FR + Office 2019 Pro / CPU 3950X + Z63 / GPU RTX 2080 Ti + G12 + H55 / CM Crosshair VIII Impact / SSD 2TB PCie 4.0 5000 MBps + HDD 3TB / 32GB DDR4-3600-CL16 Trident Z Royal Gold / NZXT H210i + RGB HUE 2
- Has thanked: 864 times
- Been thanked: 483 times
Re: EPIM Android - Contact systematically saved even if no change
1. Thank you, noted.
2. There's lots of places where "Effacer" is used, please specify which one of them you meant. Thanks!
- Laurent C.
2/ I see that in Notes, then in Contacts : I suppose the term "effacer" is false everywhere you use it for a
button and shall be changed for "Supprimer"...
Where exactly in Notes and Contacts it should be replaced?
- Laurent C.
I mean buttons OR menus for Notes and Contacts and other modules inside EPIM Android...
I wonder why you ask me where ?
You are the designer and developer of the solution who knows better than me this EPIM tool and functionalities and where to make the changes !?
I did never imagine having myself to open all the screens and menus to make screenshots for these simple modifications ?!???
Regards
Regards
There are lots of places where the term "effacer" is used in the app and since I know nothing about French (unfortunately) I cannot just go around the language file changing every single instance of the term. This could lead to some unexpected consequences.
- Laurent C.
I understand your problem
Anyway, I thus will try to give you the screenshot I found while using the tool
Soon...
Soon...
That would be great! Thank you in advance.
- Laurent C.
Here somme screens where to fix with my previous translations...
Thank you, consider it done.
- Laurent C.
Seems not done with release of EPIM 9.6.1 PC
I guess it was fixed in AEPIM 5.8.
- Laurent C.
The recent Google version today is 5.7.4 ...
Which means the update hasn't reached you, yet. Check out the news on our web site: https://www.essentialpim.com/blog-and-news
- Laurent C.
OK, thks
I will try to install the Get EPIM 5.8 APK package these later days...
EssentialPIM for Android 5.8 Released : Please note, this is a staged roll-out release, which means it might take some time till it reaches your Android devices.
