long note contents - problem
dirmansyah
Post by dirmansyah »
Hello, Android-EPIM developers.
I copied the "oxford 3000-word list" text to Windows-EPIM note. There is no problem for Windows-EPIM. I synched it to Android-EPIM.
In Android-EPIM, it takes long time to open the above note item.
While the note is being opened, Android-EPIM displays black screen for almost 30 seconds or so. That made me think it was crashed.
The same state happens while Android-EPIM closes that note.
1. Is it possible for Android-EPIM to open a long note more quickly ?
2. Is it possible to provide a pop up message saying e.g. "Opening the note. Please, wait" so that users do not think that the app is crashed ?
Thank you.
Android-EPIM Pro ver. 5.8
on
Android 10 phone 6GB/128GB
Android 10 tablet 3GB/32GB
Has thanked: 1406 times
Been thanked: 977 times
Re: long note contents - problem
Will check if we're able to implement 2 above mentioned points. Thanks!
