When i enter EPIM(android), it asks for my fingerprint to enter the main menu, ok so far, its password protection working as intended.
Then i enter Notes for example, then go back to the main menu of EPIM to choose another module, my cellphone asks again for the fingerprint. I disabled the password protect in settings but it still asks for the fingerprint every time i get to the main menu.
I basically want to enter epim, ask for the password/fingerprint only once, if i leave the app, very well, ask again for the pass/fingerprint.
Is this a EPIM setting i am failing to see or its probably some phone setting?
Security setting on main menu
- Has thanked: 1407 times
- Been thanked: 977 times
Re: Security setting on main menu
Could you please make a screenshot of the authentication window and attach it here?
- Has thanked: 28 times
- Been thanked: 6 times
The security block asking for the fingerprint happens right away with a fresh instalation of EPIM without any config, and by accident i found out i can simply cancel it without placing my fingerprint.
EPIM is the only app to do this, all my other apps act normal.
My cellphone is a Samsung Galaxy A30s, Android 10.
This isn't EPIM's authentication window... Will check that out, though.
