Note covered by +
poet-man
Has thanked: 10 times
Been thanked: 31 times
Note covered by +
Post by poet-man »
If notes are sorted manually, at the end of line there is a sort of grab-icon, by which you can move the note in the list.
If I want to move the last note at the end of screen, this grab-icon is covered by + sign, by which you can add new note (see screenshot). On my tablet it is almost impossible to grab that note and move it, because trying to lower that line and grab/move (grab-icon just about to be seen), will open Google assistant instead.
Any possibility known to move + in order to be able to grab note, or any other solution?
Re: Note covered by +
Good catch, thanks, will improve this one.
Alfhw
Has thanked: 26 times
Been thanked: 12 times
Post by Alfhw »
There is a similar problem in calendar with week and month view. The yellow plus button is too big and cover some appointments (especially in week view at 21.00-22.00 hours and in month view in the last 2 days). It's very difficult or impossible to select those appointments. Maybe the button should be smaller or moved somewhere else. What about moving it outside the black part of the screen? Maybe at the end of the row with "day", "week" etc. labels? This could a solution also for Note, To Do, Contacts etc. where the plus button often hide something behind.
I like the idea of a handy plus button but IMHO is not in a very good position.
Will see what we can do, thanks.
