Essential PIM for Android crashes on Android 10
MyPersPIM
Has thanked: 4 times
Post by MyPersPIM »
I've been using Essential PIM for many years on my smartphone.
Now Essential PIM repeatedly crashes on my brand new smartphone with Android 10. :roll:
I re-installed it, but it did not solve: Android Keep on issuing a message about Essential PIM crashes.
Has thanked: 920 times
Been thanked: 530 times
Re: Essential PIM for Android crashes on Android 10
What's the AEPIM version number? When does the crash happen?
MyPersPIM
Post by MyPersPIM »
Hello, sorry, I forgot: AEPIM ver. is 5.8.
The crash message appears when AEPIM is idle, when I'm not using it.
It also appeared when I made a synchronization with windows, but the sync succeeded anyway, it seems to be a good sync.
I'm monitoring if the message pops up again.
Today it arose 1 time, yesterday more times.
Please forward us a screenshot of the error and also click on the "Send" button if you see it when the error happens.
poet-man
Been thanked: 4 times
Post by poet-man »
Maybe there's a connection to an issue I had, but maybe no connection at all (my issue is being looked at by support):
I synced AEPIM to WinEPIM and AEPIM sync module crashed (just fell back to menu; and WinEPIM showed message "connection interrupted".
I found out, that it had to do with new notes in AEPIM, having fotos in it. As soon as I excluded notes from sync, everything was ok.
MyPersPIM
Post by MyPersPIM »
@admin
Here are two screenshots.
The error arose this morning, as soon as I switched the phone on.
Please click on the last option when this happens again "Invia feedback" and mention in the description the report is coming from you. Thank you!
MyPersPIM
Post by MyPersPIM »
Hello, I've sent you the feedback yesterday or two days ago.
Please note that each time I switch on the smartphone the error message pops up.
Looking forward to read you soon,
best regards.
We're expecting this to be fixed in the upcoming new 5.8.1 version of EPIM. Thanks!
MyPersPIM
Post by MyPersPIM »
Thank you :)
MyPersPIM
Post by MyPersPIM »
I updated to ver. 5.8.1.
But it still crashes each time I switch on /restart the phone :(
I hope it will not crash during normal use of the phone.
I have sent you the feedback via Android.
poet-man
Post by poet-man »
I had a similar problem with a different app some time ago. There it turned out not to be the app but all the things installed on the mobile. So I decided to setup mobile completely new, not installing all the small apps I didn't really need. I installed the app in question first, installed one app after another and tried in between. To see which of the other apps was responsible. None of those was. Everything was fine.
So if support doesn't find anything .........
MyPersPIM
Post by MyPersPIM »
poet-man wrote: Thu Apr 08, 2021 11:14 am I had a similar problem with a different app some time ago. There it turned out not to be the app but all the things installed on the mobile. So I decided to setup mobile completely new, not installing all the small apps I didn't really need. I installed the app in question first, installed one app after another and tried in between. To see which of the other apps was responsible. None of those was. Everything was fine.
Sure, but my phone is brand new and I installed all the same apps I had on my old phone and I keep the number of apps as low as possible: the less you install, the less you got problems and you can save memory.
And EPIM is one of the first apps I installed on my new phone.
What a mystery.
poet-man
Post by poet-man »
Well - just wanted to point at a possible reason.
On my Android10 mobile, there are no probs at all.
At least you have the possibility to completely set back your mobile and install AEPIM as the only app, to see, whether the problem still exists (just in case, nothing else brings a solution).
MyPersPIM
Post by MyPersPIM »
poet-man wrote: Wed Apr 14, 2021 9:59 am Well - just wanted to point at a possible reason.
Thank you for your suggestion, but I guess I'll keep the phone as it is: the message error arises only when I switch on or restart the phone; the app works fine - I guess - and the syncs too.
It's not a big problem, just a nuisance.
Best regards.
