Hi
Consider an Outlook note contains <> that is synced to EPIM Pro then synced to EPIM Android :
RTX 3060 <PRICE> 500 <TEMP> 900 <PW> 200
If I open the note in EPIM Android all <TAGS> are deleted :
RTX 3060 500 900 200
And, the text will sync back to Outlook deleting the <> content !
Regards
Outlook note synced to EPIM Android deletes all <>
- Laurent C.
- Has thanked: 4 times
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
- Has thanked: 1407 times
- Been thanked: 977 times
Re: Outlook note synced to EPIM Android deletes all <>
Using intermediate sync options could be prone to introducing such issues, unfortunately.
- Laurent C.
I do not use intermediate sync options
All is synced by EPIM Pro only !
Thus a bug in your tool...
Rgds
Rgds
- Laurent C.
I will add that I use other sync tools for other Outlook backup purposes, and these kind of bugs were managed and do not exist...
