Duplicates
DavidN
Has thanked: 16 times
Been thanked: 11 times
Duplicates
Post by DavidN »
Hello
I am doing a 1 way sync from PC to Android app. Using all current releases of both softwares. My phone app now has duplicates of all appointments and tasks. I do not have these same dupes on my PC.
What can I do to resolve this issue?
PeCe
Has thanked: 101 times
Been thanked: 329 times
Re: Duplicates
Post by PeCe »
I guess the easiest way is to delete all appointments and tasks in settings from the phone and then do a new sync.
DavidN
Re: Duplicates
Post by DavidN »
Thank you. Are you saying to delete from inside the app? I do not see where that setting is in the app. Can you be more specific?
dream_weaver
Has thanked: 8 times
Been thanked: 6 times
Re: Duplicates
Post by dream_weaver »
On the phone:
Settings>Purge Data
On the PC under Synchronization>Edit>[Phone]
On the first sync, consider: 1-way. Sync from EPIM to Android (EPIM->Android)
After your data is on both systems, consider switching EPIM over to: 2-way. Sync both EPIM and Android with each other.
You might find these links helpful:
https://www.essentialpim.com/help/ . . . online version
https://www.essentialpim.com/help/epim_pro.pdf . . . downloadable pdf version
DavidN
Re: Duplicates
Post by DavidN »
Thank you. I will purge the data. However, since the onset, I have only performed a 1 way sync and I am still getting duplicates.
Has thanked: 1411 times
Been thanked: 984 times
Re: Duplicates
Please also try clearing up the sync data from File->Database Management (select Android and click on the Clear button).
DavidN
Re: Duplicates
Post by DavidN »
I tried. That did not work. I also sent the log file to support on Friday morning.
Re: Duplicates
Let's use one of the support channels, then. Will continue assisting you via email.
